Marked 2 not rendering anymore
Viewed 83
// Please enter a detailed description of the issue
// Description of the issue:
Footnotes, links etc not rendering at all. This only became an issue overnight when I updated Tahoe to 26.3.1
// Please enter a list of steps required to reproduce the issue
// Steps to reproduce:
  1. Previewing from Multimarkdown Composer and The Archive
// If applicable please attach a sample document that causes the issue for you.
// Configuration (do not edit)
Marked 2 1071 (Setapp)
macOS Version: 26.3.1
additionalMathJaxConfig:
allowPageBreakInCode: YES
bookTxtIsLeanpub: NO
summaryMdIsGitBook: NO
codeIsPoetry: NO
codeCanWrap: NO
collapsibleHeadlines: NO
convertGithubCheckboxes: YES
convertGithubEmoji: YES
convertYAMLToMMD: NO
defaultMathJaxConfig: TeX-AMS-MML_HTMLorMML
defaultPreviewStyle: 4
defaultProcessor: MultiMarkdown
enableMiniMap: NO
excludeBlockQuotesFromCounts: NO
excludeFootnotesFromCounts: YES
excludeVerbatimFromCounts: NO
excludeCaptionsFromCounts: YES
folderPreviewExtensionsArray: md, markdown, txt, mdown, html, opml
githubNewlines: YES
h1IsPageBreak: NO
h2IsPageBreak: NO
hrIsPageBreak: NO
includeMathJax: NO
includeKatex: NO
limitTextWidth: NO
mathNumberEquations: NO
mathNumberEquationsSide: 0
mathNumberEquationsAMSOnly: NO
minimalJavaScript: NO
outlineModeExtensions:
permissionGranted: YES
printHeaderBottomLeft:
printHeaderBottomRight:
printHeaderFirstPage: NO
printFooterFirstPage: YES
printHeaderTopLeft:
printHeaderTopRight:
processHTMLFiles: YES
removeMetadataForPreview: NO
removeYAMLHeaders: NO
scrollToEdit: YES
shouldDetectCritic: YES
shouldHighlightMarkupErrors: NO
shouldLoadCritic: NO
syntaxHighlight: NO
syntaxHighlightOnlyLang: NO
useCustomMarkdownProcessor: YES
customMarkdownProcessor: /usr/local/bin/pandoc
useCustomPreprocessor: NO
customPreprocessor:
useFirstH1AsPrintTitle: YES
I note that you're using Pandoc as a custom processor. Does the issue persist if you disable the custom processor?
That fixed it Brett, Thanks.
I can probably do without Pandoc most of the time.
It's odd though, All was good until I updated MacOS
