Images from Bear not showing
Viewed 88
Hi, I've just purchased Marked from the App Store and am trying it out using from Bear using "Preview in Marked".
I'm finding that images are not shown, and sometimes lists are shown with an asterisk instead of a bullet. Some lists are fine, and the presence of sublists does not seem to be a factor.
Screenshot of both issues provided.
Martin
This is going to be a Bear issue more than it is a Marked issue, I think. Bear seems to be sending blank base64 images. This was working previously, so it must be a recent change in Bear. Let me know if you have any issues contacting them.
Edit: I contacted Danilo from Bear and he said it was definitely a Bear bug that they expect to have fixed by the holidays.
As far as the lists go, Markdown (all flavors) requires a blank line before a list starts. Just add a blank line and your lists will render.
