Drag-and-Drop to App Icon not fully working
Viewed 7
If I drag a single .md file from a finder window to the Marked 2 app icon, it correctly opens a new Marked preview pane.
However if I drag two or more .md files, Marked comes to the foreground but does absolutely nothing. It should create a preview pane for each file.
Known issue (for a long time), and one I haven't been able to solve, even in Marked 3.
Well the workaround is to drag one-at-a-time or open from the File/Open... menu, so it's of course not a showstopper, just a bother.
I am SO curious where the problem lies... I don't want to waste your time, but is there another ticket which has some kind of explanation?
