TOC on different frame?
Is it possible to have the HTML generated with the TOC on a separate frame so the output looks similar to the following:
https://marked2app.com/help/How-to_tips_and_tricks.html
thanks,
bernie
Support Staff 1 Posted by Brett on 14 Mar, 2019 01:42 PM
Do you mean you want it in a column on the left? That's not possible
with the export feature, but if you have the skills you could always
dissect the HTML output and create it on your own... though obviously
not a solution for automated export. Sorry.
2 Posted by Bernie Anger on 14 Mar, 2019 02:00 PM
Brett, thanks for the quick reply.
Yes, I was hoping for an automatic export feature that created a column on the left. Wouldn't that be a cool product feature?
bernie
____________________
Bernie Anger
[email blocked]
434-218-8770
www.thingscubed.io <http://www.thingscubed.io>
On 3/14/19, 9:42 AM, "Brett" <[email blocked]> wrote:
Support Staff 3 Posted by Brett on 14 Mar, 2019 02:05 PM
Then it gets into a whole templating setup that's far too complicated to
offer elegantly. At that point you're doing web design with a Markdown
tool, and supporting it across other export formats would be a
nightmare. It would be a neat trick, but overall impractical.
