Marked 2+ Scrivener 3+ Zotero 5 . for academic writing.. problem with args
I try to combine Marked 2+ Scrivener 3+ Zotero 5 together by following https://www.youtube.com/watch?v=BrZRIU8IHaI&t=120s
What args I should use
I was told it changed from -f markdown -t html5 --bibliography=filepath/testlibrary.bib --smart --normalize -s
to -f markdown -t html5 --bibliography=filepath/testlibrary.bib --smart --normalize -s
But the second one still does not work for me..
What is the correct args, please?
Support Staff 1 Posted by Brett on 22 Jul, 2018 01:27 PM
If you open Help->Show Custom Processor Log and then try to load the
file, do you get any helpful error messages from Pandoc?
