Connection from Marked to v3.paddleapi.com at startup - why?
When I start Marked 2 it tries to connect to v3.paddleapi.com. Why is this necessary and what data is transferred? Can I permanently block this connection?
Best regards Robert
Support Staff 1 Posted by Brett on 04 Jun, 2018 10:18 AM
It's how Marked validates your license. Only your license information is
transmitted on an encrypted connection.
2 Posted by Robert on 04 Jun, 2018 08:33 PM
Thank you for your answer. If I have registered my version, can I permanently block the connection without affecting the function of Marked?
Support Staff 3 Posted by Brett on 04 Jun, 2018 08:37 PM
Probably, though I've honestly never tried it. If Marked runs after you
block it, then there wouldn't be any issue moving forward unless you
need to activate it again.
4 Posted by Robert on 04 Jun, 2018 08:44 PM
Thanks, so far everything is clear!
Robert
Robert closed this discussion on 04 Jun, 2018 08:45 PM.
