How to highlight the first 5~6 words in each sentence.
I know there is highlight option in proofreading. I can also use regular express with / /, but I don't know how to highlight the first some words.
Support Staff 1 Posted by Brett on 04 Jan, 2018 10:27 PM
It would be through regular expressions, but Marked's highlighting
engine isn't advanced enough to handle such general queries without
using excessive memory. Basically you'd want to search for a terminator
[?!.] followed by a space and then groupings of non-terminators after.
But after a little testing, that's not working properly with the
highlighter.
