ISO-8859-1 encoding
I have to write a text in ISO-8859-1 (don't ask!).
Unluckily Marked 2 cannot open it. Is this by design or a bug?
Support Staff 1 Posted by Brett on 15 Jan, 2016 04:35 PM
I'm not able to replicate this locally by saving a file from Sublime
Text as ISO-8859-1 (it opens without question in Marked). Can you attach
a file with the encoding you're dealing with for inspection?
Also, is it an option to save it as UTF-8 and convert the encoding
before submission?
2 Posted by Victor Volle on 15 Jan, 2016 04:57 PM
Hi Brett!
Thx for getting back to me.
I have the file attached. And yes, I can work with UTF-8 and then convert it. I was just surprised that it doesn’t work.
btw: I use Version 2.5.3 (910)
Kind Regards
Victor
Support Staff 3 Posted by Brett on 15 Jan, 2016 05:38 PM
Are other files working fine for you?
My system recognizes that as UTF-8:
$ file ix-0.1.mmd
ix-0.1.mmd: UTF-8 Unicode text, with very long lines
And Marked opens it fine on the first try. I'm wondering if there are
any other possible issues. Could you go to Preferences->Advanced and
enable Debug mode set to "All"? Then attempt to open the file and check
the Help->Show Debug Log and let me know what you see.
4 Posted by Victor Volle on 15 Jan, 2016 06:00 PM
Hi Brett!
This is the log from two unsuccessful attempts to open the file
> 2016/01/15 18:53:36:174 | Processing document [2016-01-15 17:53:36 +0000]
> 2016/01/15 18:53:36:174 | file:///Users/vivo/workspaces/me/ix/text/ix-0.1.mmd opened with encoding 0
! 2016/01/15 18:53:36:174 | Error opening, trying again
> 2016/01/15 18:53:37:175 | file:///Users/vivo/workspaces/me/ix/text/ix-0.1.mmd opened with encoding 123145305061456
!!2016/01/15 18:53:37:175 | ERROR text is nil for /Users/vivo/workspaces/me/ix/text/ix-0.1.mmd
!!2016/01/15 18:53:37:176 | Loading failed
> 2016/01/15 18:53:37:177 | Done loading from baseURL
> 2016/01/15 18:53:37:177 | Finished processor operation
> 2016/01/15 18:53:37:177 | Window feature handling finished
> 2016/01/15 18:54:39:363 | Shutting down watchers, closing window
> 2016/01/15 18:54:56:800 | Processing document [2016-01-15 17:54:56 +0000]
> 2016/01/15 18:54:56:800 | file:///Users/vivo/workspaces/me/ix/text/ix-0.1.mmd opened with encoding 123145303451728
! 2016/01/15 18:54:56:800 | Error opening, trying again
> 2016/01/15 18:54:57:802 | file:///Users/vivo/workspaces/me/ix/text/ix-0.1.mmd opened with encoding 123145303451728
!!2016/01/15 18:54:57:802 | ERROR text is nil for /Users/vivo/workspaces/me/ix/text/ix-0.1.mmd
!!2016/01/15 18:54:57:802 | Loading failed
> 2016/01/15 18:54:57:803 | Done loading from baseURL
> 2016/01/15 18:54:57:803 | Finished processor operation
> 2016/01/15 18:54:57:804 | Window feature handling finished
> 2016/01/15 18:55:25:266 | Shutting down watchers, closing window
and this is a successful attempt with UTF-8
> 2016/01/15 18:58:40:044 | Processing document [2016-01-15 17:58:40 +0000]
> 2016/01/15 18:58:40:046 | file:///Users/vivo/workspaces/me/ix/text/ix-0.1.mmd opened with encoding 4
> 2016/01/15 18:58:40:046 | Loading ix-0.1.mmd succeeded
> 2016/01/15 18:58:40:046 | Checking for includes
> 2016/01/15 18:58:40:046 | Inserting included files (processed) from file:///Users/vivo/workspaces/me/ix/text/
! 2016/01/15 18:58:40:046 | File /Users/vivo/workspaces/me/ix/text/#compare-1.png not found
> 2016/01/15 18:58:40:046 | Watching /Users/vivo/workspaces/me/ix/text/compare-1.png (relative)
> 2016/01/15 18:58:40:049 | Extracting fenced code blocks
> 2016/01/15 18:58:40:051 | Extracted 0 code blocks
> 2016/01/15 18:58:40:051 | Extracting scrippets
> 2016/01/15 18:58:40:051 | Extracted 0 scrippets
> 2016/01/15 18:58:40:052 | Processing Markdown using internal lib
> 2016/01/15 18:58:40:052 | Using Github newlines
> 2016/01/15 18:58:40:054 | Enabling SmartyPants
> 2016/01/15 18:58:40:054 | Starting mmd conversion
> 2016/01/15 18:58:40:054 | mmd conversion complete
> 2016/01/15 18:58:40:054 | Removing "markdown='0'"
> 2016/01/15 18:58:40:055 | Processed
> 2016/01/15 18:58:40:055 | Removing "markdown='0'"
> 2016/01/15 18:58:40:055 | Inserting included files (raw) from file:///Users/vivo/workspaces/me/ix/text/
> 2016/01/15 18:58:40:055 | Watching /Users/vivo/workspaces/me/ix/text/compare-1.png (relative)
> 2016/01/15 18:58:40:088 | Done loading from baseURL
> 2016/01/15 18:58:40:088 | Finished processor operation
> 2016/01/15 18:58:40:093 | Window feature handling finished
> 2016/01/15 18:58:40:199 | JS: Beginning processing
> 2016/01/15 18:58:40:204 | JS: Starting javascript processing
> 2016/01/15 18:58:40:204 | JS: Base URL: /Users/vivo/workspaces/me/ix/text/
> 2016/01/15 18:58:40:206 | JS: Updated header IDs
> 2016/01/15 18:58:40:209 | JS: Generated TOC
> 2016/01/15 18:58:40:209 | JS: Updating collapsed sections
> 2016/01/15 18:58:40:211 | JS: Highlighting code blocks
> 2016/01/15 18:58:40:212 | JS: Updated header IDs
> 2016/01/15 18:58:40:217 | JS: Stored collapsed sections
> 2016/01/15 18:58:40:218 | JS: Updating collapsed sections
> 2016/01/15 18:58:40:221 | JS: Updating page breaks (hidden)
> 2016/01/15 18:58:40:222 | JS: Word count on selection
> 2016/01/15 18:58:40:222 | JS: GitHub task lists
> 2016/01/15 18:58:40:222 | JS: Setting up link behaviors
> 2016/01/15 18:58:40:223 | JS: Initializing spell checking
! 2016/01/15 18:58:40:223 | No spelling cache
> 2016/01/15 18:58:40:224 | JS: No spelling cache, lazy check disabled.
> 2016/01/15 18:58:40:224 | JS: Binding bookmarks
> 2016/01/15 18:58:40:225 | JS: JavaScript finished
> 2016/01/15 18:58:40:291 | JS: finished loading MathJax js
> 2016/01/15 18:58:40:291 | JS: MathJax loaded, initializing
> 2016/01/15 18:58:40:321 | JS: Syntax highlighting finished
> 2016/01/15 18:58:40:593 | JS: Mathjax: Scrolling to diff
> 2016/01/15 18:58:41:324 | JS: Fixing code block height
> 2016/01/15 18:58:41:324 | JS: Fixing code block backgrounds
Kind Regards
Victor
5 Posted by Victor Volle on 15 Jan, 2016 06:07 PM
I just tried:
so perhaps the file got mixed up or I sent the wrong (UTF-8) version? So I attached it again gzipped:
Support Staff 6 Posted by Brett on 15 Jan, 2016 06:46 PM
Yeah, that detected encoding is definitely wacky. I'll test with the new file shortly.
Support Staff 7 Posted by Brett on 15 Jan, 2016 06:59 PM
Ok, I am able to replicate now. Marked goes through a list of major
encodings in order of most common, and if it finds none that match it
takes a blind shot. I'd have to suggest working in UTF-8 if possible,
then converting, but I'll look into broadening the range of readable
types.
8 Posted by Victor Volle on 15 Jan, 2016 07:14 PM
Hi Brett!
Thank you very much for taking the time.
I _can_ work in UTF-8. Conversion with Sublime works fine.
Kind regards
Victor
France is Bacon!
