Use latex math macro
andrewchengchou's Avatar
andrewchengchou
31 May, 2015 05:34 PM
I was trying to define a latex math macro throughout one markdown file. The latex macro is to define a matrix transpose:
\newcommand{\tr}{{\scriptscriptstyle\mathrm{T}}}
I managed to do it by adding the following scripts at the beginning of the markdown file.
<script type="text/x-mathjax-config">
  MathJax.Hub.Config({
  TeX: {
    Macros: {
      tr: "{\scriptscriptstyle\mathrm{T}}",
</script>
I can then use the command \tr throughout the markdown file. For example,
  TeX: {
    Macros: {
</script>
The tranpose of a real matrix $A$ is denoted by $A^\tr$.
QUESTION: How can I make the above macro as a user default in marked 2 app? So I don't have to copy and paste the scripts for a new markdown document.
  1. Support Staff 1 Posted by Brett on 31 May, 2015 06:36 PM
    Under Style preferences, you'll see an "Additional MathJax Config"
    field. Add the part of your script that's inside the MathJax.Hub.Config
    object to that field and save:
    TeX: {
         Macros: {
  2. Support Staff 2 Posted by Brett on 31 May, 2015 06:36 PM
    You may need the include the outer curly brackets around that, I can't
    recall offhand how I have that injected. Let me know if you have issues
    and I can dig back into it.
  3. 3 Posted by andrewchengchou on 31 May, 2015 11:23 PM
    I tried both
    TeX: {
            Macros: {
    and
      TeX: {
        Macros: {
    Neither works. And there was an error popped out. Error parsing additional mathjax configuration.
  4. Support Staff 4 Posted by Brett on 31 May, 2015 11:48 PM
    Ok, I dug into it further and I have an error in the parser that
    converts the string in the preferences into a config object for MathJax.
    I'll try to have this worked out for the next update. In the meantime,
    you could use the raw include syntax to put your macros into a separate
    file and include it in documents that need it:
    <<{filename.js}
    Let me know if that helps.
  5. 5 Posted by andrewchengchou on 01 Jun, 2015 12:15 AM
    Thanks Brett. Including the outer file works well. But there is one minor issue. Instead of saving the original script, I need to modify it slightly.
      TeX: {
        Macros: {
          tr: "{\\scriptscriptstyle\\mathrm{T}}",
    </script>
    Note the double slash (`\\`) rather `\` in front of `scriptscriptstyle` and `mathrm`.
  6. Support Staff 6 Posted by Brett on 01 Jun, 2015 01:08 AM
    The code in your comment doesn't show a double slash. It's possible that somewhere along the line it's being unescaped, but Marked shouldn't be doing anything to it when using the raw syntax. I'll double check, though.
  7. 7 Posted by andrewchengchou on 01 Jun, 2015 03:19 AM
    I don't know why. My comment in the raw text form has double slashes. After formatting it in markdown, it became one slash. So I edited the comment so it is displayed in raw text.
