Syntax help from within marked?
John's Avatar
John
29 Oct, 2011 09:50 PM
The help suggests that there might be syntax help for markdown from within marked?
I.e.: "If not, see the links on the Markdown Help pages. Marked includes a full Markdown syntax guide in this help system, so you can brush up as you go."
Sorry to be so obtuse, but is there a menu item for that?
  1. Support Staff 1 Posted by Brett on 29 Oct, 2011 10:08 PM
    There's a basic formatting guide in the Marked Help documents (Help->Marked Help), as well as a link to the full MultiMarkdown documentation.
  2. 2 Posted by John on 29 Oct, 2011 11:07 PM
    John's Avatar
    Um - Literally I'm not seeing it. Nothing about foo or ### section or anything.
    See screenshot.
    How about "Syntax" as an item on the left.
  3. Support Staff 3 Posted by Brett on 29 Oct, 2011 11:16 PM
    Yep, I'll add a more descriptive link. For now, look under MultiMarkdown information.
