Quit Marked after its final window closed
Hello,
I remember there was such a feature in Marked1, which was quite handy when Marked was used a lot. Is there any chance that it will be introduced again?
BR,
Sergej
Support Staff 1 Posted by Brett on 16 May, 2021 01:06 PM
No, that feature was used by few people and was confusing to most. I guess I never understood why it was bad to just leave Marked running when you were using it a lot. It doesn't use any resources when no windows are open…
2 Posted by rclott on 08 Jul, 2022 03:30 AM
Any way to restore this functionality? Or at least completely hide Marked 2 from the dock? I really really miss it.
