Marked and Drafts by Agile Tortoise
Curious if anyone is familiar with Drafts from Agile Tortoise. They have a unique way of doing things. I love the efficiency of Marked and have been using it for ages and am also drawn to Drafts and possibly using that as part of my workflow. Wondering if there's a way these can coexist and play well together that someone might be aware of.
Support Staff 1 Posted by Brett on 13 Dec, 2019 08:40 PM
Greg recently published an action for the Mac version of Drafts (beta):
https://actions.getdrafts.com/a/11f
