Multi column Mode
Hi,
"Multi Colum" mode was mentioned as being available from the Style menu. But my Marked 2.5.31 does not show it in the Style menu, as shown in the attached images.
- multi.png 362 KB
Support Staff 1 Posted by Brett on 06 Mar, 2019 04:38 PM
You're looking under the custom styles menu, which only shows styles you add manually. If you pull down the Default style selector or use the style selector on the preview window (pictured), it's the third option.
2 Posted by Byung Lee on 06 Mar, 2019 08:14 PM
Hi Brett,
Thanks for your quick reply.One more question about transclusion. The first image shows a node in iThoghts X, which has one transclusion, abstract.md. It is displayed correctly in the second image on Marked 2. When I tried the same code with MindNode, it showed the third image on Marked 2, the transclusion code was not interpreted at all.
Where did I go wrong?
On Wednesday, March 6, 2019, 11:38:27 AM EST, Brett <[email blocked]> wrote:
Support Staff 3 Posted by Brett on 06 Mar, 2019 08:22 PM
Each mind map app is going to format the Markdown preview differently. For Marked to work with a transclude it needs to be at the beginning of the line, and my guess is that in your MindNode preview it's ending up indented.
