How to produce a numbered document?
Hi everyone! I use to use OmniOutliner in order to print numbered documents such as: I. First part 1. A section 1.1 A subsection... and so on. I use Latex too, but I would like to be free to write without having to use Latex codes. Does anyone know how I could do in order to use Marked with OmniOutliner in order to have such a result? Thank you very much for your help.
Support Staff 1 Posted by Brett on 05 Jan, 2025 11:03 AM
I'm not sure I understand the question. Do you want to produce a
numbered list? In the gear menu in the lower right of a Marked preview
window, see Outline Mode. I think that will do what you're looking for,
but let me know if I'm not understanding.
On 30 Dec 2024, at 13:28, Tullio wrote:
