Automatically decrement header levels with multi-document linking?
david.veldhouse's Avatar
10 Jan, 2018 01:49 PM
Hello all,
New to the forum, and I didn't find this in any discussions:
Is there a way to force Marked 2 to reduce header levels for multi-document files brought into a master index file?
I write a lot of technical content, and sometimes I mix-and-match different sub-sections that have multiple uses.
For example:
Header topic 1
Sub-header topic 1
...might be useful as a sub-section for a different topic, such as:
New Topic
<<[] this example I'd like to bring into with it's whole header hierarchy reduced by 1, so it's effective a sub-header of New Topic.
  1. Support Staff 1 Posted by Brett on 10 Jan, 2018 02:24 PM
    This can't be done using Marked's custom include syntax, but it can be accomplished using the mmd_merge syntax that Marked supports. Create an index file that contains nothing but filenames/paths and put #merge in the first line. You can then use indentation to manually adjust header levels:
    So if part1, 2 and have first level headers, it would now show up in the compiled document with a second-level header, and any subsequent headers within the file are decremented appropriately.
  2. 2 Posted by david.veldhouse on 10 Jan, 2018 04:10 PM
    That's great, and very useful! One problem is that I'm using Discount processing primarily due to its image scaling capabilities. I don't suppose you know if Discount supports #merge?
    Thanks again for the FAST response...
  3. Support Staff 3 Posted by Brett on 10 Jan, 2018 04:52 PM
    The merge is built into marked, it just compiles the document before passing it to whatever processor you're using.
    - Brett
  4. 4 Posted by david.veldhouse on 11 Jan, 2018 02:16 AM
    I see. That seems to work as advertised, thanks.
    Of course, I want my cake and eat it too:
    I can't build a dynamic table of contents this way like I can with Mark's slick "include" syntax, can I?
  5. 5 Posted by david.veldhouse on 11 Jan, 2018 02:21 AM
    Actually, I think I just answered my own question: putting the <!--TOC--> in the first document after the #merge command seems to work!
  6. Support Staff 6 Posted by Brett on 11 Jan, 2018 02:24 AM
    You can't stick a toc tag into the merge file, but you can create a toc.txt (or whatever) with a <!--toc--> tag in it and insert it where you want in the merged document.
    - Brett
  7. 7 Posted by david.veldhouse on 11 Jan, 2018 12:51 PM
    Yes, I ended up getting exactly the output I wanted. Thanks so much for the attention, Brett.
