tag:support.markedapp.com,2011-09-11:/discussions/questions/9027-modifying-a-default-styleMarked: Discussion 2017-10-08T17:47:04Ztag:support.markedapp.com,2011-09-11:Comment/436975792017-10-08T13:00:35Z2017-10-08T13:00:35ZModifying a Default style<div><p>The CSS for some files (like that one) contain embedded fonts. Just scroll down.</p>
<ul>
<li>Brett</li>
</ul></div>Bretttag:support.markedapp.com,2011-09-11:Comment/436975792017-10-08T17:17:58Z2017-10-08T17:18:01ZModifying a Default style<div><p>Thanks for the clarification.<br>
Like that style. Just wanted h3, h4 to get progressively smaller.</p></div>Mazhartag:support.markedapp.com,2011-09-11:Comment/436975792017-10-08T17:22:05Z2017-10-08T17:22:05ZModifying a Default style<div><p>Note that it is possible to modify things like that using the Additional CSS under Style preferences. You can add override styles there that apply to all themes. All themes also get a body class based on their filename, so you can modify just Upstanding styles with:</p>
<p>.upstandingcitizen h2 { … }</p>
<ul>
<li>Brett</li>
</ul></div>Bretttag:support.markedapp.com,2011-09-11:Comment/436975792017-10-08T17:23:34Z2017-10-08T17:23:34ZModifying a Default style<div><p>The classes are auto-assigned, I didn't double check that one. If you right click on the preview window and Inspect element, you can see the actual classes on the body tag (and even experiment with style changes live in the preview).</p>
<ul>
<li>Brett</li>
</ul></div>Bretttag:support.markedapp.com,2011-09-11:Comment/436975792017-10-08T17:28:26Z2017-10-08T17:28:30ZModifying a Default style<div><p>Thanks! I will try. Not too familiar with this, just a happy user. (But did tinker successfully earlier with one style.)</p></div>Mazhartag:support.markedapp.com,2011-09-11:Comment/436975792017-10-08T17:47:03Z2017-10-08T17:47:03ZModifying a Default style<div><h2><a name="thanks-" class="anchor" href="#thanks-"></a>Thanks.</h2>
<p>"All themes also get a body class based on their filename, so you can modify just Upstanding styles with:</p>
<h2><a name="-upstandingcitizen-h2-quot-" class="anchor" href="#-upstandingcitizen-h2-quot-"></a>.upstandingcitizen h2 { … }"</h2>
<p>This worked beautifully. All good. Thank you for responding, and so quickly.</p></div>Mazhar
