Is there a way to have a conditional block inside Marked
Amit's Avatar
23 Aug, 2017 09:20 PM
Could be really powerful and useful to me.
I am thinking something like the #ifdef structure with the C pre-processor of yore.
  1. Support Staff 1 Posted by Brett on 23 Aug, 2017 09:27 PM
    Based on what conditions?
    Brett Terpstra
  2. 2 Posted by Amit Agrawal on 23 Aug, 2017 10:22 PM
    Amit Agrawal's Avatar
    So, I was thinking that I have multiple resumes right now which I am targeting to different people and I would really like an ifdef type mechanism so I can say for example
    on top and then inside the markdown doc I can say
    * Product manager for this awesome product
    and then certain things will be included and not others.
    PS: please dont post the above on the forum.
  3. Support Staff 3 Posted by Brett on 24 Aug, 2017 02:26 PM
    This is the kind of thing that you'd want to use a custom pre-processor for. A simple script that read in keys at the top and then removed parts conditionally would be pretty easy to set up. Pre-processors run before rendering, and it's designed to allow manipulation of the text before it reaches the Markdown processor.
  4. 4 Posted by Amit Agrawal on 24 Aug, 2017 11:33 PM
    Thank you. This will work well.
