tag:support.markedapp.com,2011-09-11:/discussions/questions/8952-change-highlight-color-for-visualize-word-repetitionMarked: Discussion 2017-07-25T16:43:24Ztag:support.markedapp.com,2011-09-11:Comment/425440482017-05-12T00:37:22Z2017-05-12T00:37:22ZChange highlight color for Visualize Word Repetition?<div><p>Sorry, no, that's not something I ever planned on being customizeable.<br>
You can kind of hack it though, using the "Additional CSS" option under<br>
Preferences -> Style. Click Edit CSS and enter something like:</p>
<pre>
<code>#wrapper b.repeat { background: ...; }
#wrapper b.repeat:hover { background: ...!important; }</code>
</pre>
<p>You might need the !important on one or both to override the internal<br>
styles. You can use any css color name or compatible color (HSL, RGB,<br>
hex, etc.).</p>
<p>-Brett</p></div>Brett
