See how your posts will actually look, while you write (blogger.com)
Although I have seen the comment on the subject line in several places regarding Marked 2, I have searched unsuccessfully for how to implement it. Is it possible to implement this feature with blogger.com and, if it is, how do I go about it?
Thanks!
Support Staff 1 Posted by Brett on 08 May, 2017 06:26 PM
You can create a preview style using the CSS from your blog. In many
cases, you can copy the existing CSS file and use it with just slight
modifications. More details here:
http://marked2app.com/help/Writing_Custom_CSS.html
