Using markd with github wiki
Keith Bierman's Avatar
Keith Bierman
05 May, 2017 11:02 PM
To work offline, I've cloned a repo's wiki. Markd does a great job rendering any given file.... however, the wiki has become fairly complex, I was hoping to have a simple way to review all of the material offline ... so something like pointing markd at the top of the wiki (home.md) seemed like a good bet.,..but instead of live links, I see the markup ... like
 *. [[System Overview]]
 * [[Team Charter]... etc.
and the [[text]] aren't treated as live links.
What should I do differently to get local rendering to match what I see poking around the online version?
Thanks in advance,
khb
  1. Support Staff 1 Posted by Brett on 05 May, 2017 11:15 PM
    The double bracket wiki syntax isn't markdown, so you'd have to write a script to run as a custom preprocessor that converted them appropriately.
    You can drop the parent folder onto marked to display the file being edited, but it will only show one at a time and only the most recently modified.
    Note that Marked isn't a full browser and won't provide back/forward navigation when viewing linked files. One option is to generate an index that Marked can recognize (such as GitBook or LeanPub format) and view the whole wiki as a single document.
    - Brett
  2. 2 Posted by Keith Bierman on 05 May, 2017 11:23 PM
    Yes, it's not mark down as such ... it's a wiki (github projects have the
    code, and a standard wiki). Please consider it an RFE to handle enough of
    the github wiki language (they provide a FOSS library for processing the
    text) ... it would be a very nice touch I think.
    Keith Bierman
    [email blocked]
    303 997 2749
  3. Support Staff 3 Posted by Brett on 05 May, 2017 11:29 PM
    It's not a common enough use case to force on everyone, and the handling of wiki links varies between systems. Writing a preprocessor for marked, though, is as simple as writing a command line script, and you can handle syntax any way you need to.
    - Brett
