Displaying code syntax highlighting by default
steven.thompson.ca's Avatar
steven.thompson.ca
25 Jan, 2017 05:11 PM
Hi, is there some way to make .md documents show proper code syntax highlighting? I'm using marked2 and when I do a quicklook on a file with code
```swift
func somecode() {
 print("nothing")
It just gives me a vanilla block with no highlighting. How do I get it to display a proper preview like I would see in marked2? Thanx.
  1. Support Staff 1 Posted by Brett on 25 Jan, 2017 07:00 PM
    Do you have syntax highlighting turned on under Style preferences?
  2. 2 Posted by steven.thompson... on 25 Jan, 2017 07:30 PM
    Yes I do. To be clear, I'm looking at the file in Finder not Marked2. So technically it isn't a Marked2 question. Maybe you can point me to a post or something that answers this question. I want to see markdown files similar to the way I'm seeing them in marked2 but using quicklook. Thanx.
  3. Support Staff 3 Posted by Brett on 25 Jan, 2017 07:51 PM
    I don't know of a Quick Look generator offhand that previews Markdown
    with code highlighting, but you could hack one together using pygments
    or something. Here's my fork of Fletcher Penney's:
    https://github.com/ttscoff/MMD-QuickLook
    And here's one specifically for syntax highlighting that you might be
    able to incorporate:
    https://github.com/n8gray/QLColorCode
Already uploaded files
  • Screen_Shot_2017-01-25_at_12.09.16_PM.png 82.2 KB
