How to have two instances of Marked running?
Hi Brett
How can I have two instances of Marked running? I'm planning to have one using the build-in markdown processor, the other one the custom processor.
Many thanks,
Leo
Support Staff 1 Posted by Brett on 21 Jul, 2016 02:51 AM
Are you asking how to have the same document open in two windows? You
would need two instances for that, and should be able to use the method
detailed here:
http://www.cnet.com/news/how-to-open-multiple-instances-of-an-application-in-os-x/
If you're looking to just run different processors on different
documents, the custom processor can be toggled per document, and you can
include a metadata directive to specify what processor to use per
document. http://marked2app.com/help/Per-Document_Settings.html
