Header variable for current chapter?
adam.wathan's Avatar
adam.wathan
15 Mar, 2016 02:30 PM
Just wondering if anyone knows of a way to display whatever the value of the "current" H1 tag is in the header of exported documents? Even if it means doing it manually somehow. Can't seem to find a way to have "dynamic" variables other than the page number.
Attached a screenshot with an example.
  1. 1 Posted by adam.wathan on 15 Mar, 2016 02:31 PM
    Sorry, attachment didn't seem to work the first time.
  2. Support Staff 2 Posted by Brett on 15 Mar, 2016 02:53 PM
    No, this can't be determined at print time. I can access page
    measurement data, but not the content I would need to parse the most
    recent headline value.
  3. 3 Posted by adam.wathan on 15 Mar, 2016 04:20 PM
    No biggie, just wanted to ask just in case :) Thanks Brett! Love Marked.
