In Markdown write poems in fenced blocks???
I want to find a good way to write poems with lots of soft line breaks in markdown.
I tried fenced bocks with the class poetry, but
this doesn't work when I need emphasis in a poem, because fenced
blocks are meant for code and don't allow the use of Markdown
inside the block. :-(
At the moment I Use normal text with th two spaces at the end, but here I cannot force left indentation of indivual lines.
So what can I do to get both? What can I do?
Support Staff 1 Posted by Brett on 22 Dec, 2015 01:04 AM
Markdown really isn't built for this. Either a block is code, or it's a
paragraph. You could do some styling on blockquote tags instead, if you
wanted to use ">" before each line. If you set the whitespace:pre
property in the CSS, it should still preserve indentation. Haven't
tested that, though.
