Syntax highlighting Advanced Preference in 2.4.10 no longer works
Steve West's Avatar
Steve West
14 Feb, 2015 08:15 PM
Just updated to 2.4.10. Was using GitHub for Default style but had Syntax Highlighting set to something dark so code blocks would stand out more. Syntax highlighting is checked in Preferences > Style > Advanced > Syntax highlighting. Selecting any css file and clicking the Apply button makes no different in the markdown preview of a .md file containing several codeblocks.
  1. Support Staff 1 Posted by Brett on 14 Feb, 2015 08:52 PM
    I think there may have been an issue porting your preferences to the
    new, non-sandboxed version. If you could, please quit Marked, delete the
    file at ~/Library/Preferences/com.brettterpstra.marked2.plist and try
    re-launching. A reboot may be required to flush the preference cache, so
    if nothing changes, try deleting again and restarting your machine
    before relaunching Marked.
    If that doesn't fix the issue, please let me know.
  2. 2 Posted by Steve West on 14 Feb, 2015 09:35 PM
    Steve West's Avatar
    - deleted the plist specified, no change in ability to designate
       alternate syntax highlighting.
       - deleted plist specified, quit Marked 2, restarted, no change in
       ability to designate alternate syntax highlighting
    anything else I can try or provide to you to help debug?
    Steve
    ____________________
    Steve West
    [email blocked]
    (704) 775-8477
  3. Support Staff 3 Posted by Brett on 14 Feb, 2015 09:42 PM
    Just to clarify, did you quit Marked _before_ deleting and restarting?
    This is my iPhone. There are many like it, but this one is mine.
  4. 4 Posted by Steve West on 15 Feb, 2015 05:02 PM
    Steve West's Avatar
    Brett,
    Yes I quit Marked _before_ deleting and restarting.
    But I just did it all again to make sure and still no joy with Syntax
    Highlighting.
    I was starting to think there was something whacked on my machine.
    I remembered that I hadn't updated Marked on my laptop. It is running 2.4.9
    and the syntax highlighting works fine.
    I renamed Marked 2 on my MacPro from "Marked 2" to "Marked 2.4.10". I
    zipped, copied, and unzipped 2.4.9 in Applications folder to my MacPro.
    Now on the MacPro, Marked 2.4.9 syntax highlighting works fine while Marked
    2.4.10 does not perform Syntax Highlighting.
    2.4.10
    [image: Inline image 1]
    2.4.9 using the same markdown file, same Preference settings
    [image: Inline image 2]
    Steve
    Steve West
    [email blocked]
    (704) 775-8477
  5. Support Staff 5 Posted by Brett on 15 Feb, 2015 07:32 PM
    I'm still believing there's an issue with the main preferences system.
    The difference between 2.4.9 and 2.4.10 for direct sale customers is
    that 2.4.10 removes the OS X security feature, sandboxing. Thus, it
    stores the preferences in a new location outside of the sandbox.
    To verify that this is the issue, please open a preview window and type
    control-option-I. Pressing escape once should focus the input field at
    the bottom of the console. Enter this (paste it in):
    Marked.config.inspect();
    Let me know what you see.
  6. 6 Posted by Steve West on 15 Feb, 2015 10:09 PM
    Steve West's Avatar
    [Log] Cocoa preferences (marked.min.js, line 1)
    [Log] (marked.min.js, line 1)
    [Log] JS preferences (marked.min.js, line 1)
    [Log] reduceProcessing: (undefined) undefined (marked.min.js, line 1)
    reduceHeavyProcessing: (undefined) undefined
    enableMiniMap: (undefined) undefined
    checkLinksOnLoad: (undefined) undefined
    shouldScroll: (undefined) undefined
    shouldHighlight: (undefined) undefined
    shouldCollapseHeadlines: (undefined) undefined
    shouldHighlightErrors: (undefined) undefined
    shouldLoadCritic: (undefined) undefined
    shouldShowIncludesChart: (undefined) undefined
    shouldHighlightRepeats: (undefined) undefined
    requireCmdClick: (undefined) undefined
    snapToWords: (undefined) undefined
    shouldConvertGitHubTasks: (undefined) undefined
    savedAtBottom: (undefined) undefined
    showDocumentProgress: (undefined) undefined
    wordCountOnSelection: (undefined) undefined
    showStatusBar: (undefined) undefined
    showOnlyInvalidLinks: (undefined) undefined
    enableZooming: (undefined) undefined
    if a screenshot would be better...
    Steve West
    [email blocked]
    (704) 775-8477
  7. Support Staff 7 Posted by Brett on 15 Feb, 2015 11:19 PM
    I emailed you a test build privately.
Already uploaded files
  • Style.jpg 94 KB
  • _vagrant-cheatsheet_md.jpg 46.7 KB
