Centered hash mark for manuscript.
lou's Avatar
lou
06 Feb, 2015 07:17 PM
Hi there
How do I create a centered hash mark to display in manuscript theme as an end of scene marker. I've tried # # and also tried ###### # (I saw this in the comments of a css file on github.)
Thanks
Lou
  1. Support Staff 1 Posted by Brett on 06 Feb, 2015 07:26 PM
    Depends on whether you're using Discount or MultiMarkdown setting in the
    Processors preferences.
    With Discount, just use:
    With MMD, you'd need custom CSS that centered text at a certain header
    level (such as ###### for header level 6, in which case your latter
    example would work). You could do this by going to the Style preferences
    and in the Additional CSS field adding:
    h6 {
    text-align: center;
  2. 2 Posted by lou on 06 Feb, 2015 08:08 PM
    lou's Avatar
    Hi Brett
    Thank you for the super quick reply. The Discount GFM setting with the syntax that you indicated worked great. When I tried the other suggestion it worked with ###### #test but not with ###### # with last hash alone. I've attached the screen shots. Thanks again and have a great day.
  3. Support Staff 3 Posted by Brett on 06 Feb, 2015 08:24 PM
    Try it with a backslash before the #:
    Haven't tested, but should work.
  4. 4 Posted by lou on 06 Feb, 2015 10:25 PM
    lou's Avatar
    It worked perfectly. Many thanks for the help.
    -Lou
