tag:support.markedapp.com,2011-09-11:/discussions/questions/8166-ithoughts-integration-reverse-exampleMarked: Discussion 2015-01-09T03:34:10Ztag:support.markedapp.com,2011-09-11:Comment/357337012015-01-09T03:34:08Z2015-01-09T03:34:08ZiThoughts Integration (reverse example)<div><p>No, but you can import the Markdown file directly in iThoughts
and then<br>
open the resulting document in Marked.</p>
<p>-Brett</p></div>Brett
