How to specify print headers and footers per document
Brett,
I'd like to use this new feature: "Allow print headers and footers to be specified per-document using MMD metadata" but I don't know the syntax. I checked the Marked help and your website but didn't find a description.
I tried
Top Left: some text
Header Top Left: some text
but both do not work.
Could you please provide a short example? Thanks.
Support Staff 1 Posted by Brett on 10 Sep, 2014 08:41 PM
See this section of the help.
Available headers are:
2 Posted by Steinthal on 11 Sep, 2014 05:01 PM
Sorry, I did not look there... I'd expected the description in the Per-Document settings of the help.
Thanks for your help, Brett.
Support Staff 3 Posted by Brett on 11 Sep, 2014 05:02 PM
I need to reorganize all the help topics and index them better, it's
something I'm working on.
Thanks!
