tag:support.markedapp.com,2011-09-11:/discussions/questions/6407-figure-definition-and-figure-footMarked: Discussion 2016-08-11T03:16:10Ztag:support.markedapp.com,2011-09-11:Comment/339779082014-07-31T18:26:51Z2014-07-31T18:26:51ZFigure definition and figure foot<div><p>The text used in the title becomes both the alt tag and the
figcaption element in MultiMarkdown. You have to use this
format:</p>
<pre>
<code> ![Anything in here will go into the **alt** attribute and **figcaption** tag][fig_15_003]
[fig_15_003]: 15/15_003.png "Anything out here only gets put into the 'title' tag of the image"</code>
</pre>
<p>Not all of the built-in themes are great at figcaption display,
I need to work on that. If you need some custom CSS to help out,
let me know.</p></div>Bretttag:support.markedapp.com,2011-09-11:Comment/339779082014-08-01T16:31:03Z2014-08-01T16:31:03ZFigure definition and figure foot<div><p>I've been trying that syntax and it's exactly what's I need,
thanks a lot. I will take a better look at MultiMarkdown.</p>
<p>I've noticed something strange, though. This gets rendered:</p>
<p>![Anything in here will go into the <strong>alt</strong>
attribute and <strong>figcaption</strong> tag][fig_15_003]</p>
<p>But this doesn't:</p>
<p>![**Anything** in here will go into the <strong>alt</strong>
<p>Notice that the bold mark is first in the caption. If I include
an space at the beginning of the caption then it gets rendered:</p>
<p>![ <strong>Anything</strong> in here will go into the
<strong>alt</strong> attribute and <strong>figcaption</strong>
<p>I'm using version 2.2 (825).</p></div>enreastag:support.markedapp.com,2011-09-11:Comment/339779082014-08-01T17:07:49Z2014-08-01T17:07:49ZFigure definition and figure foot<div><p>A link/image title has to start with an alphanumeric
character.</p>
<p>-Brett</p></div>Bretttag:support.markedapp.com,2011-09-11:Comment/339779082014-08-01T17:43:59Z2014-08-01T17:43:59ZFigure definition and figure foot<div><p>Oh, I see. Thanks again.</p></div>enreas
