How to use Marked 2 for slides/presentations?
pmilin's Avatar
pmilin
27 Jul, 2014 09:58 AM
Hi all! I just started using markdown and I wonder can anyone give us some examples of how to use Marked 2 for presentations/slides?
Thanks, PM
  1. Support Staff 1 Posted by Brett on 27 Jul, 2014 11:14 AM
    While Marked makes an excellent preview and a great way to create PDFs
    for your presentations, it's not really geared toward any kind of fancy
    slideshows. You can do it with some hacking around, but if you want to
    turn Markdown into great presentations, I highly recommend checking out
    Deckset:
    http://decksetapp.com/
    Marked _is_ great as a teleprompter, though :)
    http://brettterpstra.com/2013/12/27/using-marked-2-as-a-teleprompter/
    If you have a specific presentation need that you think Marked should be
    able to handle, let me know and I'll see what I can think of.
  2. 2 Posted by Max on 18 May, 2016 04:50 PM
    Max's Avatar
    Hi Brett,
    I really would like use marked2 for my presentations 'cause I fall in love with my custom CSS ;-) so my prior is export to pdf as slide format.
  3. Support Staff 3 Posted by Brett on 19 May, 2016 01:34 PM
    =?UTF-8?B?Wjp4nE2OMW7DMBAEe75iHyDnCwZcpUg6A6lP4joiQPKUu5Nh/d5Ul2Kxzc5g
    f1YJ8CVL1ANZceiOTmY81LAZnT0kivYr7iuNkBHnkyYVn/fvr8ssPubp/xZ+
    eLA54rSfylZ+18A88LkSoSh9UdvUJDhh3gMlkDI39uwYhgEZjH97MbbhdYjj
    IXbWoj1MKxpj1ewTcvGtynF+bhITEmP5SOlyM0a8AYT+UV0=
