tag:support.markedapp.com,2011-09-11:/discussions/questions/6358-support-for-nisus-writer-proMarked: Discussion 2016-08-11T03:17:55Ztag:support.markedapp.com,2011-09-11:Comment/338261312014-07-18T17:06:17Z2014-07-18T17:06:17ZSupport for Nisus Writer Pro<div><p>Nisus files are rich text (a proprietary version of RTF), which
Marked<br>
does not handle by default. There are macros you can use in Nisus
to<br>
generate Markdown, though. I use one for TidBits, I'd have to ask
them<br>
if it's available for public sharing or not.</p>
<p>-Brett</p></div>Bretttag:support.markedapp.com,2011-09-11:Comment/338261312014-07-18T17:09:29Z2014-07-18T17:09:29ZSupport for Nisus Writer Pro<div><p>Brett,</p>
<p>If you could send me the macro or a variation of it or give me
some hints I would be grateful.</p>
<p>David R. Calvert<br>
<a href=
"mailto:david.r.calvert@me.com">david.r.calvert@me.com</a><br>
505-919-8505</p></div>david.r.calverttag:support.markedapp.com,2011-09-11:Comment/338261312014-08-18T15:32:13Z2014-08-18T15:32:13ZSupport for Nisus Writer Pro<div><p>Brett,</p>
<p>Do you think that a RTF to Markdown service would be a good
project? How difficult would that be for you?</p>
<p>Do you have any suggested workflows that could be used for RTF
to Markdown?</p>
<p>How about a Macro that could be used for public use?</p>
<p>Thanks in advance for your help.</p>
<a href=
505-919-8505</p></div>david.r.calverttag:support.markedapp.com,2011-09-11:Comment/338261312014-08-18T15:39:12Z2014-08-18T15:39:12ZSupport for Nisus Writer Pro<div><p>I've done some RTF -> Markdown scripts, but RTF is messy
and<br>
unpredictable. A NWP macro makes more sense, as it has a certain
amount<br>
of predictability to it. I'm currently using a proprietary one that
I've<br>
been asked not to share, but I can probably come up with a
reasonable<br>
facsimile when I get time.</p></div>Bretttag:support.markedapp.com,2011-09-11:Comment/338261312014-08-18T15:47:54Z2014-08-18T15:47:54ZSupport for Nisus Writer Pro<div><p>Thanks,</p>
<p>Please let me know when you come up with the NWP macro.</p>
<p>Meanwhile I will try building some macros as well.</p>
<p>I also thought of exporting rtf to HTML and then using one of
your service tools or Pandoc to see what I come up with.</p>
<a href=
