tag:support.markedapp.com,2011-09-11:/discussions/questions/4485-could-use-help-with-the-search-functionMarked: Discussion 2013-12-28T22:42:48Ztag:support.markedapp.com,2011-09-11:Comment/308058422013-12-28T17:41:11Z2013-12-28T17:41:11ZCould use help with the search function<div><p>The search bar works just like any OS X find bar, type Escape to
dismiss it while it's focused. If you've clicked out of it, type
⌘F, then escape.</p>
<p>Top margin can be added in a few ways. The easiest is to add
margin-top or padding-top to the #wrapper element.</p>
<pre>
<code>#wrapper {
padding-top: 50px;
}</code>
</pre>
<p>I can't guarantee results on other people's styles, but that
should work.</p></div>Bretttag:support.markedapp.com,2011-09-11:Comment/308058422013-12-28T20:56:27Z2013-12-28T20:56:27ZCould use help with the search function<div><p>Thanks Brett.</p>
<p>I can imagine you shaking your head at that first question
– so simple and I've been using Macs for years. :) I'm not
sure I've ever used ESC shortcut for exiting a Find search. Usually
I've clicked a "done" button or it's been a separate, closeable
Search/Find window. Lesson learned.</p>
<p>The #wrapper code worked perfectly.</p>
<p>I appreciate the solid support once again. Enjoy your New Year's
holiday.</p></div>m_conntag:support.markedapp.com,2011-09-11:Comment/308058422013-12-28T21:02:03Z2013-12-28T21:02:03ZCould use help with the search function<div><p>I'm so used to being keyboard-centric I didn't think about a
close button… I'll fix that.</p></div>Bretttag:support.markedapp.com,2011-09-11:Comment/308058422013-12-28T21:21:42Z2013-12-28T21:21:42ZCould use help with the search function<div><p>Sounds good. I'm getting to be more and more keyboard centric,
but Find functions have recently become more useful and a bigger
part of my workflow than before, so I just hadn't come across the
need for ESC shortcut yet.</p></div>m_conn
