Ulysses III Problem or Marked Problem?
Hi Brett,
I'm trying out Ulysses III for writing technical manuals, and inadvertently bumped into Marked's (really cool) multi-page document support. Your help doc clearly says that each .md section reference needs to have an empty line above and below it, yet my Ulysses-generated .marked file looks like this:
<<[Cover.md]
<<[Introduction.md]
<<[The Essentials.md]
The literal text "<<[Cover.md]" is printed in the Marked preview, while each other section is parsed and beautifully rendered like I'd expect.
If I add a single line break at the beginning of the file, all sections are loaded and parsed. Since Ulysses' automatic management of this file is a rather nice feature, to whom does this parsing issue belong?
Clearly you're not in the business of supporting Ulysses, but am I correct in thinking it's their problem?
Support Staff 1 Posted by Brett on 18 Dec, 2013 10:02 PM
Looks like it was a problem in my own regex. I have it fixed for the
next update. I have some testing I need to finish on another feature for
that update, but it should be out this week.
2 Posted by Matt Stein on 18 Dec, 2013 10:22 PM
Cool, and thanks for the quick response!
Brett closed this discussion on 26 Dec, 2013 09:55 PM.
