Retain footnote popup window in exported document?
Hello,
Marked 2 includes an amazing preview in which footnotes (and critic markup comments) are automagically displayed while hovering over the in-text links. Is it possible to retain these features within an exported document?
Thank you for creating this incredibly useful software!
Support Staff 1 Posted by Brett on 30 Sep, 2013 05:51 PM
Not really, Marked is able to do this because it can carefully control the environment, scripts and markup. It is possible to replicate with some scripting, though, and I'll consider posting some "plugin" scripts for people to use when I have time.
