Wrapping of source code depending on output format
The code formatting using the github flavor is a great thing for my manual writings.
But the horizontal scrollbar in wide code segments naturally doesn't work in PDF, RTF, ... output.
Is there a switch to wrap wide lines of code for printable output.
Thanks
Uwe
Support Staff 1 Posted by Brett on 02 Sep, 2013 08:14 PM
You can do this by adding some custom CSS.
pre {
white-space: pre-wrap;
white-space: pre-line;
2 Posted by Uwe Peuker on 02 Sep, 2013 08:39 PM
Thanks for the fast reply.
So easy! It will help me to understand and adjust the output to my needs!
