Does Marked work with Evernote?
Just curious if Marked provides the live HTML preview window for notes composed in Evernote?
Thanks.
BJ
Support Staff 1 Posted by Brett on 13 Sep, 2011 12:16 PM
That would be impossible on multiple levels, but primarily because Evernote stores all of its data in a database instead of files that Marked can watch and read from. You can, however, use the Service "Preview Selection in Marked" to grab what you're editing at any time and view a full MultiMarkdown render of it in Marked. Sans live update, of course, but you can assign a hotkey to it for quick previews.
2 Posted by BJ Thaman on 13 Sep, 2011 12:39 PM
Thanks for the quick response. Sounds like a workable option!
BJ Thaman
Brett closed this discussion on 13 Sep, 2011 01:42 PM.
