Printing the help
Alan Bristow's Avatar
Alan Bristow
12 Oct, 2012 07:56 PM
Hi,
Is there a way I can print the help under 'Help, Markdown Reference' and 'Help, Keyboard Shortcuts'?
I can copy/paste this but it's so nicely formatted already :)
Cheers, -Alan
PS: Thank you for this excellent app.
  1. Support Staff 1 Posted by Brett on 12 Oct, 2012 11:57 PM
    If you look inside the Application bundle
    (/Applications/Marked.app/Contents/Resources) you'll find
    MarkdownOverview.html and KBShortcuts.html, which you can open in a
    browser and print.
    To get to them from Finder, right click on the Marked application and
    choose "Show contents of package".
  2. 2 Posted by Alan Bristow on 13 Oct, 2012 01:35 PM
    Thanks Brett! :D
  3. Brett closed this discussion on 13 Oct, 2012 01:44 PM.
