Footnotes using superscript tag
don's Avatar
don
12 Aug, 2012 04:44 AM
Is it possible to have superscript tags enclosing a footnote's anchor tag? It seems that's all that's necessary to allow the Footnotify extension work on my footnotes.
  1. Support Staff 1 Posted by Brett on 12 Aug, 2012 01:41 PM
    It's not possible for the user to modify the output of the internal MultiMardown 3 processor. You can, however, set up a custom processor or run the output through a conversion script, so if you know of a processor that creates the output you need and need help setting that up, let me know.
  2. 2 Posted by don on 19 Aug, 2012 12:52 AM
    don's Avatar
    Thanks, Brett! I wouldn't want to replace the MMD processor, so this post offers hope that a small processor could be added which would simply wrap links with specific classes in <super> tags. (I guess I'd have to suss out writing a processor...)
  3. Support Staff 3 Posted by Brett on 26 Aug, 2012 07:57 PM
    Yep, the preprocessor is built and will hopefully allow the additional processing you need.
  4. Brett closed this discussion on 26 Aug, 2012 07:57 PM.
