Setext style headers
chad.reynoldson's Avatar
chad.reynoldson
22 Jun, 2012 12:46 PM
I cannot get the Setext-style H1 to display properly. It always shows it as a literal ======. I can get the H2 to show properly. Is there a trick?
  1. Support Staff 1 Posted by Brett on 22 Jun, 2012 01:01 PM
    Please post some sample text to show me how you're using it.
  2. 2 Posted by chad.reynoldson on 22 Jun, 2012 02:16 PM
    My Project Name
    Section 1
  3. Support Staff 3 Posted by Brett on 22 Jun, 2012 03:25 PM
    That renders fine for me in Marked. Are you using any kind of custom processor? Can you send me a screenshot of what you see when you load that?
  4. 4 Posted by chad.reynoldson on 22 Jun, 2012 06:40 PM
    Brett, screen-shot is attached. Thanks for the assistance.
  5. Support Staff 5 Posted by Brett on 24 Jun, 2012 02:14 AM
    I can't explain this, but I can replicate it in 1.4. It's not happening in 1.5 with the same files, so the issue is fixed. I don't know what's going on in the current version, but consider it solved for the next one...
