Reference-Style Links
's Avatar
chris
19 Jun, 2012 01:07 PM
Is there anyway to have Marked display the hover URL for reference style links like it does for in line links? Also even though the reference-style links appear as links in Marked, I am unable to click on them. Thank you.
Regards,
Chris
  1. Support Staff 1 Posted by Brett on 19 Jun, 2012 01:50 PM
    Can you send me a sample? This shouldn't be an issue.
  2. 2 Posted by Christopher Joh... on 19 Jun, 2012 03:12 PM
    Christopher Johnson's Avatar
    Brett,
    I have placed a sample below. Thanks for your help.
    For the longest time I have hosted my photography at [Smugmug][], and my overall experience with them has been nothing but pleasant. But after a certain amount of time I just got tired of the design of Smugmug so I set off to find a new solution. It just so happens that after I started looking for a new image hosting service I started seeing a lot of talk a new site called [500px][].
    The first place I heard about 500px was from well known author and photographer [Scott Kelby](http://www.scottkelby.com). Scott wrote a couple of blog posts about 500px and he was generally very positive and he had this to say:
    [Smugmug]: [http://www.smugmug.com]
    [500px]: [http://www.500px.com]
  3. Support Staff 3 Posted by Brett on 19 Jun, 2012 03:20 PM
    The format is incorrect. There should be no square brackets around the reference links themselves.
    [Smugmug]: http://www.smugmug.com
    [500px]: http://www.500px.com
    That should fix the problem.
  4. 4 Posted by Christopher Joh... on 19 Jun, 2012 03:30 PM
    Brett,
    My mistake, thank you for your help and sorry for wasting your time.
  5. Support Staff 5 Posted by Brett on 19 Jun, 2012 03:35 PM
    No problem!
