Links betwen Marked documents?
Joel Dubiner's Avatar
Joel Dubiner
12 Jun, 2012 07:10 PM
I'd like to have a syntax where I can follow a hyperlink from one marked document to another.
Is there a URL handler for Marked? Something like:
mvim://open?url=file:///etc/profile
but for Marked...
I would like to use Marked as a filesystem based Wiki, and this would be a useful tool.
  1. 1 Posted by Joel Dubiner on 12 Jun, 2012 07:51 PM
    Here's a screen grab of the URL Handler from MacVim, taken from xcode.
    Should be pretty easy to add 'marked://blah' as a URL handler.
  2. Support Staff 2 Posted by Brett on 25 Jun, 2012 02:32 PM
    I'll look into adding this. Marked should just open a file if the linked file is Markdown using the 'file:///Users/yourname/Desktop/heythere.md' link if it's being opened from within Marked itself, though.
