Index
SBN's Avatar
SBN
04 Jun, 2012 05:23 PM
Hey! :)
I'm currently writing in Byword and getting my output from Marked! Wonderful combination! :)
But now I have a problem concerning indexes in formulas:
When I write something like this: $ H_{U_1} $, everything is displayed as expected.
But when I try this in a \frac [ example: $ \frac{H_{U_1}}{H_{U_1}} $ ], Marked seems to not recognise it as a formula and I didn't get a nice formula in the output.
Am I missing something? (I'm new to MultiMarkdown/Latex etc.) Is there a workaround?
Thanks in advance! :)
  1. Support Staff 1 Posted by Brett on 04 Jun, 2012 05:36 PM
    I know zip about MathJax. Can you attach a complete document with both working and non-working parts?
  2. Support Staff 2 Posted by Brett on 04 Jun, 2012 05:41 PM
    This works for me, by the way: `\\[ \frac{H_{U_1}}{H_{U_1}} \\]`. Syntax is a bit different...
  3. 3 Posted by SBN on 04 Jun, 2012 06:00 PM
    SBN's Avatar
    Thanks for the quick reply! :)
    Your syntax is working for me, too! :D But is there a way to display the formula inside text? Now there is a paragraph and my text in the next line...
  4. Support Staff 4 Posted by Brett on 04 Jun, 2012 06:03 PM
    I think so:
         Bla bla bla \\({x}^{2} {y}^{2}=1\\).
  5. 5 Posted by SBN on 04 Jun, 2012 06:06 PM
    SBN's Avatar
    Perfect!! Thank you very much! :)
  6. Brett closed this discussion on 07 Jun, 2012 01:41 PM.
