Display of Block quotes
Block quotes display in Marked without the Vertical line on the left. Is this a setting that I need to change?
Support Staff 1 Posted by Brett on 31 Mar, 2013 06:12 PM
There is no vertical line on block quotes. Blockquotes in Markdown are just a tag that you make appear any way you like. You can add custom CSS for this if you need to, or just change the default style to one that suits you.
