Use with TextWrangler
I'm new to Markdown and learned about your product today. Sounds like the ticket for me. I'm a writer, not an HTML coder. I currently use TextWrangler... does Marked work with it as you show in your video? I know, stupid basic, but just want to confirm my understanding. Thanks very much and best of luck with your venture. --Doug Garfield
Support Staff 1 Posted by Brett on 30 Mar, 2013 01:02 PM
Yep, if it saves files to disk or iCloud, Marked will work with it.
2 Posted by Doug Garfield on 30 Mar, 2013 02:18 PM
Thank you for your response. Very much appreciated. I'm going to be a
Marked man today. --Doug
Brett closed this discussion on 30 Mar, 2013 07:43 PM.
