Fountain Format: Lines Per Page
ivo.welch's Avatar
ivo.welch
16 Aug, 2024 05:57 PM
Most screenplays are written to about 53-58 lines per page (not including page numbers). https://screenwriting.io/what-is-standard-screenplay-format/ .
I am counting the lines coming out of Marked, and it looks more like 48 lines. Because the first heuristic is to count pages as minutes, this is more of a problem than usual.
Can this be changed?
  1. Support Staff 1 Posted by Brett on 16 Aug, 2024 08:08 PM
    Marked uses Fountain’s own library and its output should match anything that other fountain apps are creating. It’s not something I’m interested in reimplementing as a standalone processor.
    On Aug 16, 2024 at 1:00 PM -0500, ivo.welch <[email blocked]>, wrote:
  2. 2 Posted by ivo.welch on 16 Aug, 2024 08:22 PM
    ivo.welch's Avatar
    upstream then... will try to ask there. is the code from fountain.io ?
  3. Support Staff 3 Posted by Brett on 16 Aug, 2024 09:07 PM
    Correct. They haven't updated it in years, but it's working as expected.
    On 16 Aug 2024, at 15:22, ivo.welch wrote:
