DEVONthink item links and multi-file documents
I am using DEVONthink more and more with marked as the former's text editing capabilities are developing. One thing I would like to do is to use DEVONthink's item links in multi-file documents. Is there a manner in which to get this to work? Example below:
<!--2 meta- Spectrum & arkivering-->
{{x-devonthink-item://420CC61D-EA6E-40FB-80B1-9A271A07E2A8}} <!--3 front- Spectrum & arkivering-->
{{x-devonthink-item://10E379EF-94C9-4E20-A832-404E3B289DB1}}
Dette notats formål
{{x-devonthink-item://CE69243A-3848-40F2-A84C-471926306F8C}}
Spectrum prosedyrene
Ni primær prosedyrer
Mottak av objekter
{{x-devonthink-item://9C1DDD1F-E7D5-49EA-8A3F-4ADC456C1BBB}}
Support Staff 1 Posted by Brett on 06 Oct, 2023 12:02 PM
Do you mean actually embed the content from those links? Because just
turning them into working links would be easy with a custom processor,
you would just need the regex:
/\{\{(.*?)\}\}/, '<$1>'
Could be done with Bash (sed), ruby, python, whatever.
But embedding the content into a larger document won't be possible.
On 6 Oct 2023, at 4:04, Birger wrote:
2 Posted by 79164 on 06 Oct, 2023 12:07 PM
Thank you for the swift response. I thought of embedding so it would render as one long complete document. I shall have to think of another way to do it.
