Audio
The audio for you video at http://markedapp.com/ isn't working. Is it supposed to have audio...I assume so. I tried it in Safari and Chrome. No luck.
Do I need Multimarkdown to create tables or can I create them in Marked?
Support Staff 1 Posted by Brett on 18 Apr, 2012 08:23 PM
There is no audio. I find audio annoying on product videos :).
Marked has MultiMarkdown built in, and can export your HTML directly, so you don't need anything extra.
2 Posted by Markedfan on 18 Apr, 2012 08:36 PM
Thanks, Brett. I watch rather than listen then. I bought Marked at the App Store a while back and only just got round to using it. It looks fun!
I like your website. It's excellent. Very elegant, informative and well-presented. I'll write a review at the App Store once I've played around with Marked. If I like it I will post a positive review. I never post negative reviews…I just don't post if I don't like a product. Marked looks really good. I want to produce tables in Marked if I can. I'll search your manuals to see if I can do it.
Thanks for the quick response. That's a thumbs up already!
Kind regards
Graham
Support Staff 3 Posted by Brett on 18 Apr, 2012 08:49 PM
I'm the same way with reviews (I write for TUAW and brettterpstra.com). If something sucks, it's really not worth spending the time writing _anything_ about it :).
Tables are one of the more complicated parts of MultiMarkdown, but they're not too hard (nothing in Markdown is). The syntax is well spelled-out here:
https://github.com/fletcher/MultiMarkdown/wiki/MultiMarkdown-Syntax-Guide
Just search for the tables section. You can also use the MMD tools to clean them up for readability without having to worry about spacing:
http://brettterpstra.com/quick-tip-clean-up-your-multimarkdown-tables/
