tag:support.markedapp.com,2011-09-11:/discussions/questions/10-marked-and-cross-referencesMarked: Discussion 2011-10-06T14:26:03Ztag:support.markedapp.com,2011-09-11:Comment/104449032011-10-06T13:29:21Z2011-10-06T13:29:21Zmarked and cross references<div><p>Hi Matthew,</p>
<p>The version of MultiMarkdown 3 that is used in Marked required
cross-reference targets to be headlines: <code>## Section 1
[sect1]</code>. A link to that would look like <code>[Linked
text][sect1]</code>.</p>
<p>Thanks,<br>
Brett</p></div>Bretttag:support.markedapp.com,2011-09-11:Comment/104449032011-10-06T14:07:24Z2011-10-06T14:07:26Zmarked and cross references<div><p>I believe my links are in the format you. For example I use:</p>
<h2>Preparation [section-preparation]</h2>
<p>with the link to it being:
[Preparation][section-preparation]</p>
<p>All this works fine in ByWord. But when I open in Marked what I
see is just this code, not an actual link. (Note: links I've
written in Byword to URLs show up in Marked just fine).</p>
<p>I'm attaching a sample document that shows up fine in ByWord,
but cross refs don't work in Marked.</p>
<p>I realize I may be doing something wrong, but it seems like I'm
on target. Perhaps there's some small detail I'm messing up on.</p></div>Mathew T. Mitchelltag:support.markedapp.com,2011-09-11:Comment/104449032011-10-06T14:16:28Z2011-10-06T14:16:28Zmarked and cross references<div><p>I just tested your document in the new version of Marked, and it
works perfectly, but version 1.2 might have something strange going
on. I updated the version of MultiMarkdown for 1.3, so this should
fix it. The new version should be out today or tomorrow. It's been
approved, I just need to get some press materials ready for the
release.</p></div>Bretttag:support.markedapp.com,2011-09-11:Comment/104449032011-10-06T14:19:42Z2011-10-06T14:19:45Zmarked and cross references<div><p>Gotcha. Okay, now I'm mega excited about 1.3!!!!! As I
understand it 1.3 will allow for multiple custom CSS styles (this
is a huge improvement for me). I'm very happy to hear MMD has been
updated also. Six months ago I didn't even know about Marked. Today
I can't imagine working without it. Killer app.</p></div>Mathew T. Mitchelltag:support.markedapp.com,2011-09-11:Comment/104449032011-10-06T14:26:02Z2011-10-06T14:26:02Zmarked and cross references<div><p>Thanks for the kind words :). Look for the update soon!</p></div>Brett
